Insert a field in a dynamic block and set to today's date but will not update when you load drawing - Thanks Byron
Check your Fieldeval system variable setting.
Controls how fields are updated.
Type: | Integer |
Saved in: | Drawing |
Initial value: | 31 |
The setting is stored as a bitcode using the sum of the following values:
Value |
Description |
0 |
Not updated |
1 |
Updated on open |
2 |
Updated on save |
4 |
Updated on plot |
8 |
Updated on use of ETRANSMIT |
16 |
Updated on regeneration |
Hello @ByronU78KM
This is an issue with using the "date" field from "date & time" field category. You would need to use the command "UPDATEFIELD" for the "date" field . Instead use the "date" field from the "system variable". This will update with "regen" and there is no requirement of using the "UPDATEFIELD" 🙂
@vinodkl But the OP doesn't want the field to update
Howard Walker
