Images within a dynamic block
engineeringTVTWR
engineeringTVTWR
Community Visitor
Community Visitor
Hello, is it possible to have an image check with visibility state in a dynamic block or within AutoCAD in general?
Issue: I have a standard drawing border that I use over various various clients. What I would like to do is change visibility state or a field that changes the images automatically to a given client. If it could be done by field that would be extremely handy and I could then adopt the visibility state for the portrait and landscape.....
I trust the above makes sense, if you have alternative methods it would be appreciated.
Libbya
I believe you can change what image is visible within a dynamic block using visibility states.  A change to a field value will not drive any parameter changes within a dynamic block.
engineeringTVTWR
Community Visitor
Community Visitor
Thank you for the reply Libbya.
I can change the visibility state of the image as noted, however I was hoping to place the images in an MS Excel file and reference then in via the lookup parameter. I am not sure this is possible? It certainly can be done for dimensions to manipulate blocks based on a lookup state, maybe not images. I want to create a drawing border with maximum flexibility, I suppose to only way would be to make the border dims a lookup to change from landscape to portrait? The image could then be a standard visibility state.
Libbya
You can certainly add a visibility parameter to a lookup parameter and have the lookup change the state.
If you are able to drive changes to a lookup by changing field values (or any other method external to Autocad) I would like to know how.  I do not believe that is possible in stock Autocad.
vinodkl
Why go with visibility when you could use layers to freeze the images(use different layers for different images) which you don't need. I am  using the same method.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
