Hoping for some clarity here because I've seen it done in a block before, but I don't have access to the block to review it. I can't find an appropriate forum question either as using "attribute" and "rotation" in a search yeilds the same results which isn't what I'm after.
I'm trying to create a block that can be rotated. However, I'd like to have text on that block that states the block's current rotation. For example imagine I have a block which is a line with attribute text at the top of it. If in the block properties, I rotate that block to be 121°, I'd like the text to update to state 121° automatically.
Currently, I am using attributes and manually entering the block's rotation into the attribute, however when I have multiple of these blocks I'd like to know if there's a way to automate this. If anyone can point me in the direction of the correct resources I can use for this it would be greatly appreciated, or a block & method I can study. Thanks,
