How to Maintain Spacing after Attributes with Text
johnw
johnw
I have some attribute that are in between some text and when the attribute values change, they either get too far away from trailing text or get too close. Is there a way to maintain the spacing as the attribute value changes?
Image attached has an example of a simple block that has text and attributes within it. The attributes are in YELLOW. The two lines of text below are the results of entering different values and you can see the wider gaps or no gaps.
Any help would be appreciated.
John
h_s_walker
If I remember correctly @Libbya is one of the better ones to help here.
I know you can create "invisible" attributes which you can then reference by "field codes" in your long string of text and they will always be correctly spaced.
Howard Walker
Left Handed and Proud
Libbya
Add an attribute that will display the entire line of text.  Within that attribute's default value add the text and fields referencing the individual attribute values.  Do not edit that attribute.  Edit the individual attribute values.  If you need further assistance, post the block.
