Dynamic grips disapear after using a constraint action on the block
r_de_nier
r_de_nier
This is the case I have a traffic sign pole leader dynamic block. On the end of the leader I want to place on or more traffic signs. These signs I want to constraint to the leader so when I stretch the leader the signs move with the end of the leader. It is not possible to put all posible traffic signs in the dynamic block of the leader blocj it self. The possibilities are to huge that this will cause to many visibility states. Parametric contstraints and dynamic blocks are not going along is my experience. Jus try to constraint a line with any dynamic block and you will see the grips are gone. If anyone has a solution for this? You will help my so enormously.
Libbya
You cannot add external constraints to a dynamic block without eliminating the dynamic abilities of the block, period.
