How to keep text orientation in a rotation parameter
marcbartolucci
Message 1 of 9
marcbartolucci
I am making an interior elevation callout block. It will have 4 triangles to point a direction, with an assigned letter for each (attached is an image of what it looks like). I am adding a rotation parameter for when the need arises.
What I am trying to do, is have the letters rotate around the block with its assigned triangle, while maintaining its orientation. So if I where to rotate the block 30 degrees, those letters will still point upwards.
Please describe if possible... Thanks for the help!
Replies (8)
Message 2 of 9
Libbya
Post the block with every inquiry.  Your png is not at all useful but your block file would be.  It's easy to make a screencast, but a pain to start from scratch.  It's also a pain to type out the description of what to do as opposed to making a screencast shows every detail.
Add a chained gripless point/move.  Add the text to the move's selection set.  Rotate the point/move but do *not* rotate the text.
Message 3 of 9
marcbartolucci
Attached is my current block. I am not sure what you mean
Message 4 of 9
Libbya
Message 5 of 9
I don't know if your solution is the same as my directional compass sollution, maybe it will help.
  As far keeping text orientated properly during rotation, I made a Directional Compass with text that stays oriented correctly as well as stays centered in place, when the whole block is rotated.
 I drew out my Compass and then placed a letter at each of the 4 points.  I placed a circle concentrically around each letter.  I then went to each letter separately, and made it a block.  I snapped to the circles center point as an insertion point. When selecting objects I only selected the letter, not the circle.  At the completion of each block (a single letter) I opened the block editor and selected the letter.  In the properties box, FIRST under Annotative, I selected YES. Next under Match Orientation, I selected yes.  Now I erased the circles that were around the letters.  I now I made the entire symbol a block.  Next I opened the block editor and on the Parameters tab I assigned a Rotation Parameter.  Next on the Action tab I assigned a Rotation Action.  I closed the block editor and saved the changes while doing so.
  Now click once on the block and grab the circular grip to rotate the block.  The letters stay centered and orientated correctly.
Message 6 of 9
I don't know how to edit my last post, I had left out a Constraint Status  step.  so I am reposting.
 I drew out my Compass and then placed a letter at each of the 4 points.  I placed a circle concentrically around each letter.  I then went to each letter separately, and made it a block.  I snapped to the circles center point as an insertion point. When selecting objects I only selected the letter, not the circle.  At the completion of each block (a single letter) I opened the block editor and properties box.  I selected the letter.  In the ribbon under manage, I selected Constraint Status.  In the properties box, FIRST under Annotative, I selected YES. Next under Match Orientation, I selected yes.  Now I erased the circles that were around the letters.  I now I made the entire symbol a block.  Next I opened the block editor and on the Parameters tab I assigned a Rotation Parameter.  Next on the Action tab I assigned a Rotation Action.  I closed the block editor and saved the changes while doing so.
Use the download link on my previous post to get the compass I made.
Message 7 of 9
Hi, I have a similar dynamic block with attributes that for some reason refuse to move when following your sequence of steps. I have managed to be able to make it work when it is only one attribute, however it does not work when working with 4 attributes. please see attached block. any help is greatly appreciated
Message 8 of 9
ojuris
hi!
give each attribute unique name - for example VIEW1 VIEW2 etc.
Message 9 of 9
Thank you!!!!
That solved the issue.
Best regards
