How to keep object in dynamic block always straight in viewport
martin.hong
martin.hong
Hey guys,
I have a dynamic block of a tree being removed with a X through it, but I have several different viewports with different UCS orientations. Is there a way to make it so that the X in the block always faces straight in the viewport? Not sure if I need to make the block annotative or something... I attached the CAD as well.
Thanks!
h_s_walker
It can't have visibility states. See the attached drawing.
I would suggest you use scale parameters for each "Visibility and set them to 0 and then use a lookup parameter instead of visibility states.
Howard Walker
Left Handed and Proud
