- Mute
- Permalink
- Report
I want to create a camera block that can have range of viewing angles. The current camera block that we are using has about 20 visibility states starting 10 degrees (shown in picture) to 90 degrees (also shown in picture). As shown in the picture, the two white lines show the 10 and 90 degrees camera angle. I added distance action parameters to the two camera angle lines in the 10 degrees camera to be able to adjust the distance where needed. The problem is that I would need to do this for every single visibility states of this block which got me thinking. Is there a way to add an angle parameter to those two white angle lines and link it to an attribute such that I can type in any angle I want and it automatically adjusts? I would like to get rid of all the visibility states and be able to adjust the angles via an attribute. If not, any other ideas would be appreciated.
