How to change dimension automatic
Message 1 of 8
Hello all. I need help. I have a block like this. I need to change dimension of beam automatic. If beam type A = 300X600 ; B = 150 x 300 ; C = 200X400
please help me. Thanks.
Replies (7)
Message 2 of 8
h_s_walker
Is it just the text that is changing or are you in fact wanting a rectangle of the correct size?
Howard Walker
Left Handed and Proud
Message 3 of 8
just text on dimension attribute.
Message 4 of 8
h_s_walker
Not quite how you wanted it.
You choose the beam type and the leg and it changes the text for you
Howard Walker
Message 5 of 8
Its work for me. But can you do it with field? like if function for excel. because i have hundreds type of beam. its so long if use visibility.
Thanks brother
Message 6 of 8
MMcCall402
Add a Block Properties Table in block editor. I the upper left corner push the Add Properties button and choose the Beam Type attribute and the Dimension attribute (in that order)    Now to to excel and select all the cells with the beam type and dimensions, copy them to the clipboard, return to autocad and paste them into the block properties table.  Save your way out of the block editor.  Test block.  Choose beam type via grip on block properties
table grip.  A regen will update the dimension.
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
Message 7 of 8
Wow Thats work friend. Thanks for solution. 🙂
Message 8 of 8
it more easy when using visibility.
