How do I rotate and move the insertion point with the dynamic block?
Message 1 of 10
Hi all,
I have successfully created a dynamic block with a move parameter and 5 rotation parameters around its corners. However when I rotate or move the block, the insertion point does not rotate or move with it. All other parameter will rotate and move with the block just fine.
I have tried to add the insertion point to the action set of the move and rotate actions but cannot select it.
I have included 2 simplified screenshots (only 1 rotation point). The first showing before rotation, the second after.
Thanks!
Replies (9)
Message 2 of 10
ojuris
hi!
Why you don't post block?
What you think we can do with screenshots?
I don't know what others in forum think about screenshots but it makes me angry.
Message 3 of 10
I've attached the block to this post.
Hope this is what you are after!
Many thanks
Message 4 of 10
j.palmeL29YX
If you upload your block (.dwg) we can surely help you. Only the pics are useless.
(Maybe help you the hint that you must include the explicit defined basepoint in the selection set of the rotate action).
cadder
Jürgen Palme
Message 5 of 10
Hi there,
I have attached the block in the reply above.
As for your suggestion, I have tried to add the insertion point to the rotate actions but it will not select. It remains completely independent of the rest of the object.
Many thanks!
Message 6 of 10
Updated block with all rotation/move/visibility actions
Message 7 of 10
j.palmeL29YX
I don't know how you defined the insertion point. In the given situation I'd do it as shown in the attached screencase. (only one rotate action modified. You have to do this with the other actions too).
https://autode.sk/2B6JzxE
cadder
Jürgen Palme
Message 8 of 10
ojuris
You must place basepoint in 0,0 point in block and add it in all move and rotation action excluding move action for text
Message 9 of 10
Thanks for the reply.
Some very helpful information!
Message 10 of 10
For some reason when I tried this originally it didn't work.
Worked fine this time though so thanks for the suggestion!
All is well now!
