第 1 条消息(共 10 条)
不适用
08-14-2018
05:04 AM
Hi all,
I have successfully created a dynamic block with a move parameter and 5 rotation parameters around its corners. However when I rotate or move the block, the insertion point does not rotate or move with it. All other parameter will rotate and move with the block just fine.
I have tried to add the insertion point to the action set of the move and rotate actions but cannot select it.
I have included 2 simplified screenshots (only 1 rotation point). The first showing before rotation, the second after.
Thanks!
已解决! 转到解答。
