How do I automatically space these lines without the block falling apart?
- Mute
- Permalink
- Report
My team has been using blocks with these zone lines spaced out.
So I attempted to build these into a dynamic block. But the parametric tools are confusing me. Normally these blocks don't need this and only have an adjustable Length and Width. But due to these lines needing to be moved based on a parameter, I'm confused on the process in AutoCAD.
Each line is a Zone edge and are spaced by the intended parameter/or preferably attribute of Zone. The last zone won't always be equal to the other zones...
Can someone please look at this and show me what could be a better way?
Am I supposed to constrain everything to the origin?
(attached block is simplified for explanation.)
Inventor: Model States is not a replacement for iParts / iAssemblies. It does not have all the same features yet and does not communicate well with our large currently in use libraries. 😞 https://forums.autodesk.com/t5/inventor-ideas/model-state-support-tabulated-parts-list/idc-p/11360616
