Help with block
JCTinc07
Help with block
JCTinc07
HI,
I have a block that I added an array to and a stretch command. I want to stretch the block up and have it add behind another piece of the block as it goes up. It doesn't seem to add though just stretch. Any suggestions on how to correct this issue.
D
Libbya
The stretch window does not go around the array's linear parameter's endpoint.  Correct the stretch window and it will array properly.
JCTinc07
Thanks it worked like a charm
