help: simple ISO frame with stretch and table values not working
andrea_ricciNMVSG
andrea_ricciNMVSG
my ISO frames block (A0,A1…), which is a simple rectangle with two stretch actions and the possible values inserted in a table, doesn't work anymore. I can't find the error. In the attached sample it works in one layout and it's unpredictable in the second one. Can you help?
Everybody is welcome to use it, but please help me fix it!.
Thank you
h_s_walker
@andrea_ricciNMVSG
It's your stretch windows. They're too far away from the lines. Move them to approximately where the red lines in the images below are and you should have no more problems
Howard Walker
Left Handed and Proud
andrea_ricciNMVSG
Thank you, your solution fixed it, even if I had to add a move action for some segments that remain outside of the stretching frames.
Anyway I'm a bit confused why the hell the frame shape can be so confusing: the selection and actual points involved are the same.
Thank you again.
