Please watch the .mp4 demonstration of what i need, also the jpg picture and the dwg of the block.
Please note, i don't just want to keep the attribute text on horizontal, but the attributes and the line that cuts the circle.
Resuming, i want to rotate the text and the line inside of the circle
I haven't found in any forum something that considerates rotating atts and objects
Thanks!!!
Solved by guilherme.lepinski.sc. Go to Solution.
Your post doesn't make sense to me. If you want the attributes and line between them to remain horizontal while you rotate the section/elevation line, then simply don't rotate the attributes and line between them.
Post your block if you need further assistance.
Why don't you simply not include the attributes and line between them in the rotate action's selection set?
The center of the circle is the center of rotation. You state that you both want the attributes and line to rotate but that you don't want them to rotate. You can't have both.
I see, sorry for the confusion.
Correcting my quote:
"Resuming, i DON'T want to rotate the text and the line inside of the circle"
BUT WANT THE REST OF IT TO ROTATE
If you don't want them to rotate, then remove them from the selection set of the rotate action.
