I'm working at adjusting hatch patterns within blocks and would like to to be able to move my hatch origin either with a grip or through a user parameters, user parameters would be the preferred method as I'm hoping I would control via the properties palette and if common parameters existing between blocks I would be able to adjust hatches origins across multiple blocks if possible. This is a work in progress and although my main objective is to adjust the origin of the hatch; rotation, dynamic scale etc are all items I want to explore. I've seen the scale function used but am not having any luck with my dwg which is attached.
