In attchment you can find my file. FOTO-RICHTING.dwg
This is a dynamic block
When I change this block (with a hatch in it, that rotate with an action), a little bit, and I will redefine it in a drawing.dwg, also in attachment. Then the hatch is not following the rotation, of the different existing blocks, that had already been made. (see also printscreen in attachm.)
Thanks for a possible solution.
Solved by marcbrac. Go to Solution.
I am not sure if I understand right what you do (or try to achieve) nor what you did ("When I change this block"?). As I can see in your drawing.dwg: some of your inserted blocks Foto-Richting look as they would be damaged - the hatch is wrong placed. That can easily be "repaired": Click at one of these block references and open the block editor. Do nothing but save the block definition. close the block editor and all is ok.
If I misunderstood your problem, please explain again ...
Jürgen Palme
