Hatch cannot update automatically in dynamic block
Hello Experts,
 I need to insert a dynamic block into the drawing, there is a hatch object in this dynamic block, and it has distance property as below:
when I insert it to new drawing by RealDWG V20.0 and changed its property distance, the result block reference as bottom picture, the hatch didn't update.  I' m using AutoCAD 2015. The attachment is the testing file.  Do you have any suggestions?  Thank you.
h_s_walker
Add the hatch to the stretch
Howard Walker
Left Handed and Proud
I added the hatch to selection, the result is same, the hatch also cannot update when block update.
h_s_walker
After I posted that I downloaded your block and tried. It stretches perfectly for me. See the attached drawing
Howard Walker
Yes, it works fine when insert this block in manually, but I insert it by program(RealDWG). I attached a result file, this file created by RealDWG. The first looks the hatch is incorrect, but if I change the distance property from the properties panel , the hatch update immediately.
edwin.prakoso
Have you tried to contact RealDWG support? Because when we insert it using AutoCAD it doesn't have any issue, the problem probably on the RealDWG.
Cheers,
Edwin Prakoso
I also think it's a RealDWG issue. I didn't contact RealDWG  support and I have not their contact infomation. Thank you.
