Grid Line Dynamic Block: Rotation and Stretch doesn't work well with each other
elemenopitiyuvi
elemenopitiyuvi
hi! can anyone suggest a solution to my problem.
I want to create a grid block that has the ability to be rotated and to be stretched at both ends.
In its default orientation, I want the head and the segmented portion of the straight line to be stretched horizontally so that I may be able to adjust the position of the bubble when grid lines are too close to each other.
The stretch action is working just fine until I rotates the block.
edwin.prakoso
By "rotates the block," did you mean you rotate it using the dynamic block grip? Because when I tried to rotate it using the rotate command, it worked well.
Your rotate action doesn't include the text. That's why when you use the grip, the text doesn't follow the rotation action.
Try the attached block. Does it work as expected now?
Cheers,
Edwin Prakoso
elemenopitiyuvi
No, the rotation is working well on the text.
For the text I used the point parameter and stretch action and then chained to the rotation. the text is excluded from the rotation so that it remains horizontal.
this is how it looks like when I use the rotation grip.
the rotation is somehow having an unwanted effect on the stretch action
Libbya
Here's how to fix it:
elemenopitiyuvi
Thanks a lot
