Flatten option in Block editor, 3d to 2d Help!
Hi everyone,
I have done some block but unfortunatly didnt check if FLATTEN option is done correctly. Later when I try FLATTEN in block editor several things got deleted. Anyone know painless method how to do that?
vinodkl
Hi @Anonymous,
Try using "FLATSHOT" command to get the 2D view(block) of the solid objects and replace it inside the block.
See attachment.
Note that flatshot cannot replicate the 3D solid completely, therefore you might see very few lines missing which might need to add to the block when you compare it with 3d block when in visual style 2d wireframe🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
But when I use FLATSHOT only attributes are remaning. Can you show me how did you do that?
vinodkl
Hi @zgorenac03,
Here is the screencast
