Errors in dynamic block
S_S_SS
S_S_SS
Hello every one
I've made a complicated  dynamic block with more visibilities and more parameters , geometric  and dimensional constraints
but if I need to make any more edit on it even I draw a line in a far area …..
the block gives me this message before it closed
and the block make don't work correctly after that
the hatches converted from associative to non associative
even I've worked more and more in the past and It didn't make this error ….
see the attached block
thanks in advance
j.palmeL29YX
You must not use Dynamic Parmeters/Actions and Constraints at the same time!
(see also >>here<<)
Jürgen Palme
S_S_SS
okay sir
thanks ....
