Error: !dbspace.cpp@4793
when I try EXPLODE my dynamic block I see error: !dbspace.cpp@4793
what is it caused?
Does the error still occur if you redefine your block ?
1- Export and Import:
-Export the Block as a DWG using the WBLOCK command (Refer to the Video: Redefine Blocks Using Wblock/Insert)
-Insert this DWG into the drawing where you want to redefine the block using the INSERT command
-Upon the insertion you are prompted if you want to redefine the existing block (as it has the same name) with this new definition. Choose "Redefine Block"
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-r...
Charlie
