editing existing dynamic block
Hello!
I have one problem with custom dynamic block from Acad, which was already existing,when I have installed Acad.
The problem is- I can only stretch the block to definied points. For example it is impossible to stretch to 950, when I am trying to write this parameter, the door are stretching to 900... which is definied.
Is there any solution to change or add any points?
Best Regards
Michal
Charles_Shade
Welcome to the Autodesk Forums!
Posting the DynBlk instead of a picture of the DynBlk is the best way to get help on your block.
I suspect that there is a limit on the Parameter that controls the width of your door.
Opent he DynBlk in he Block Editor and click on that Paramter that controls the width.
You should open the Properties Palette for theis entity when you click on it. Look in hte Value Set dropdown and see if there is a Dist maximum set.
If so remove this or change to the Maximum that you want.
