EDIT ATTRIBUTE VALUE WITH LISP
Hi this is my very first time posting here.
I need to solve this problem: I've an Excel sheet with some different blocks with attributes. I need a LISP routine to insert  directly the block with the correct attributes.
I'm getting started through programming in LISP
Thanks!
Libbya
This post would be more appropriate on the LISP forum:  https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130
