I hope somebody can help.
On the attached:
A. This represents 2 Lighting Columns (Red) situated on a footpath (White) connected by Cables (Blue). I want to be able to extract the lengths of Cable to a excel sheet.
B. So, I have created blocks to represent the Cables (continuous polyline) with stretch parameters and a Length field in the attributes. This works fine in example A.
Because the radius of the footpath in this example is larger than the radius in A, I added a 3rd stretch parameter on the radius.
C. I can get the desired effect, the radius increasing and by stretching the horizontal and vertical stretch parameters can get the cable to fit between the Lighting Columns.
However, the thickness of the polyline is also increasing.
I haven’t added a scale parameter.
So, does anyone know why the thickness is being affected by the stretch parameter?
Thanks in anticipation.
Crawford
