Dynamic slope for ground model
AlexKDJ24
Message 1 of 12
AlexKDJ24
Hello there, I am new to creating dynamic blocks and although I have been able to make simple ones, I cannot find a solution to this issue.
Want I want to do is create dynamic block that reads in two Z co-ordinates, measures the distances between them and returns a Gradient 1:xxx with a slope arrow. I can see how you read in the X and Y but not Z and likewise I can create a block with movable grips in X and Y but it does not seem to function in Z. Is this possible? Please can someone help.
Replies (11)
Message 2 of 12
AlexKDJ24
Or even an Lisp routine would do, but I was trying to be clever 😃
Message 3 of 12
MMcCall402
I put together a sample to show how it could be done.  I used a construction line, an attribute with a field formula with other fields, and a polar parameter with a couple stretch actions to move things around.  The attribute formula takes info from the construction line, its length, end Z and start Z.  When the block is used its grips pick up the elevation of the objects they snap to.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Message 4 of 12
j.palmeL29YX
@AlexKDJ24 wrote:
... dynamic block that reads in two Z co-ordinates,
? "read coordinates" ?
Where are the Z-coordinates coming from? Do you want to type the values anywhere or do you want to measure an existing object (or two points) or ... ?
How shall the result look? Can you show us an example?
Jürgen Palme
Message 5 of 12
AlexKDJ24
That is awesome! thanks very much and for the quick response!
Message 6 of 12
AlexKDJ24
Thanks again, but on a closer look, this is not giving the correct answer, for instance in the example you sent, the distance between the two points is 94.37 with a rise of 5.0, which should return a gradient of ~1:19 but it does not. It was very close to what I was looking for, but inaccurate.
Message 7 of 12
AlexKDJ24
Thanks for your response Jürgen,
Sorry I was vague, I am trying to measure between two existing entities on a ground model, so similar to the previous answer, I am looking for a block which essentially measures itself. Snap one grip to one end of the surface / area (an existing entity) and snap another grip to another existing entity and the block works out the gradient as a 1:xxx fall with a directional arrow aligned to the block.
Message 8 of 12
AlexKDJ24
Mark,
Looking at it again, the problem appears to be coming back to the issue I was having before, that the grips do not appear to pick up changes in Z (elevation) so when you alter the grips on the block it changes the length as intended, but not the change in height (z) therefore does not calculate correctly.
Message 9 of 12
j.palmeL29YX
Dynamic block are designed for use in 2D only. So I'm afraid there is no way to get what you want.
But with a little LISP you can write a tool which askes you for the two points and places the slope text between the two points as shown above. The disadvantage: you can not dynamically drag the points. If you change the geometry, you must delete the slope text and run the LISP again.
If you can life with that handling I can show you tomorrow an appropriate LISP example (or, if you are in hurry, you shoud ask in the LISP forum).
Jürgen Palme
Message 10 of 12
MMcCall402
It appears like it just as Jürgen says, dynamic blocks are only 2D.   I didn't pay enough attention to the values I was getting.
If you were using Civil 3D this would be very easy.  A simple slope label on a line object, done.
I was toying around with a dimension to see if it was possible to put a field in the dimension text what could access the start and end z values of the dimension.  No luck.   I did notice that you could put in a field for those properties of an associated line and calculate its slope and the dimension would follow the line because it was an associated dimension.
Mark Mccall
CAD Mangler
Message 11 of 12
AlexKDJ24
Jürgen and Mark,
Thank you very much for your help. I was coming to the conclusion that perhaps it was only 2d.
But Jürgen, I would be very grateful if you could assist with a Lisp routine, that would work just as well. I have looked at lisp routines before, and use a few (premade) ones regularly, but am no good at coding.
thanks
Alex
Message 12 of 12
j.palmeL29YX
Attached a first rough draft of a LISP (after loading the .lsp file start with SLOPE).
Obviously you calculate the X in the slope 1:X with horizontal distance divided by the vertical distance of the both points. I'd do it reciprocal - vertical distance divided by the horizontal distance. But that's your choice. You only need to change the line
slope_num (/ delta_xy delta_z)
to
slope_num (/ delta_z delta_xy)
(and choose an appropriate number of decimals
slope_str (rtos slope_num 2 0)
change to
slope_str (rtos slope_num 2 3).
Of course you can (should) refine this draft to your needs.
(defun c:slope (/)
  (setq	p1	  (getpoint "\nFirst point: ")
	p2	  (getpoint "\nSecond point: ")
	p2_	  (list (car p2) (cadr p2) (caddr p1))
	delta_z	  (- (caddr p2) (caddr p1))
	delta_xy  (distance p1 p2_)
	angle_xy  (angle p1 p2_)
	halfway	  (polar p1 angle_xy (/ delta_xy 2))
	slope_txt (strcat "1:" slope_str)
  (command "text"
	   "_J"
	   "_BC"
	   halfway
	   3.5
	   (/ (* 180 angle_xy) PI)
	   slope_txt
  (princ)
Jürgen Palme
