Dynamic Door Schedule w/ Multiple Lookups
I have a simple block depicting glass make-up using a LOOKUP feature.  Works well enough, but spacer & muntin finish availability changes depending on the width.  Is there some way to have "CLEAR" become visible when a certain thickness is selected?  And Dark BRONZE or LT BRONZE when other thicknesses are selected? It could be text or an object, or maybe an attribute.  Doesn't matter to me as long as it works!
Don
h_s_walker
Posting the drawing usually helps. Then we can see the problem for ourselves and hopefully work out a solution for you
Howard Walker
Left Handed and Proud
Sure thing!
So the idea would be that when the space in the middle equals .5, then CLR and LT BRZ would display. When another thickness happens, say .375, then only DK BRZ will display.  If this can be done, then I would apply it to another block for muntins. What I am trying to do is eliminate impossible spacer/muntin combinations. In the infamous words of Forrest Gump.  "It happens".
Thanks!
Don
ojuris
may be that way?
That works well but what is it doing?  'Splain it to me!
ojuris
I use 2 linear parameters and scale unnecessary text to very small text
and add 2 columns in lookup to do it automatically
Very cool.  I think that should work just fine!  Thanks!
