Dynamic Door Block with Attached Door Size
Is there a way to create a dynamic door block that automatically attaches a door size to it as you adjust it? For example, if I place a 2668 door block in my plan, but stretch it up to a 3068, is there a way to make that tag update automatically?
h_s_walker
A field code attached to the distance parameter with a regen will do what you want
Howard Walker
Left Handed and Proud
I'm still pretty new to creating dynamic blocks. How do I do that?
vinodkl
Here is screencast which shows how you can display the door size by using field in attribute. I have used the door from the tool palette.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
