Dynamic Dominoe Blocks with multiple visibilities and parameters
Message 1 of 25
Hi !
Just seeking some advice if at all possible.
We have a domino joint that we wish to make Dynamic, I have made them all dynamic within theirselves and then hoped to nest them all together but after further research i believe this isn`t possible..
Basically i want to first of all with one arrow select the domino size (ie; 4x20, 5x30 , 6x40, 8x40, 8x50, 10x50) from there i want to be able to pick the required view (ie; Front, front hidden, side, side hidden, plan ).
Does anyone have any suggestions? we do have a dynamic screw with similar functions and are trying to create our own library.
Thanks for your help !!!!
Replies (24)
Message 21 of 25
what is [0.) ?
Message 22 of 25
ojuris
in lookup you can define not only exact number but also more than 1 number or range of numbers
more than 1 number - use comma;  1,2,3
for range - use parentheses
(0,1) = all numbers between 0 and 1 not including 0 or 1.
[0,1) = all numbers between 0 and 1 including 0 but not including 1
[0,1],4 = all numbers between 0 and 1 including 0 and 1 and also including 4.
(0,) = any value greater than 0 but not including 0
(,4] = any value equal to or less than 4.
(,4],6,[7,8] = any value equal to or less than 4 and 6 and any number between 7 and 8 including 7 and 8.
Message 23 of 25
I have filed this 🙂 thanks,
If you get chance for a screencast so i can see your order process that would be amazing !
thanks again
Message 24 of 25
ojuris
screencast for domino block
Message 25 of 25
ojuris
screencast for dowel block
