Dynamic Bock and Dimensional Constraint Problem
Hello all,
In the attached file there is a dynamic block, the blue box. In the lower right corner there is text showing the scale of the viewport that is inside the box. The text contains a field that will update to show the scale of the viewport automatically when the viewport scale is changed.
Here's my problem,
I need the text to remain at the lower right corner of the box during the stretching of the dynamic block. I've tried using dimensional constraints but this caused the dynamic block to stop working, it wont stretch.
BTW: Using AutoCad 213 SP2
I need help please!
DRBJR45
ojuris
why You do not use attribute
I've tried an attribute and text, I need to insert a field into the attribute or text that is associtated with a viewport scale factor so the text will show correct scale of view whenever the scale of vp changes. I cannot create a block that contains a viewport thus allowing me to accomplish this. lol...did that make sense?
Don
ojuris
do you see the file what I send?
do REGEN after change a scale
sorry, I did not see you sent a "fixed" file to me......wow, thats what was trying to do....let me look at my process again and see what I was doing wrong, but you did something Ive not seen before,,,,,the viewport is limited in choices of scale....I assume this is annotative....let me study what you did,,,,this is wonderful.
Thanks for your help!
don
