Dynamic Blocks sometimes work
To whom it may concern,
I can get dynamic blocks to sometimes work while other times they refuse to. Once I was here with a clock issue where the hands refused to rotate under the Lookup parameter, and after much discussion, I found that the block in AutoCAD LT was not created. So I recreated it and for some reason, it worked after going back into Block Edit. Now, after creating a block of a wrench, I am running into the same issue. Here I need to stretch the metric wrench and make it smaller. The wrench stays the same size after going through Block Edit. I have tried recreating the wrench into a block several times before going into block edit. It still does not work. I even deleted the file and started over, yet, it still does not work.
Here are the parameters used - XY Parameter, then in Action - Stretch, I then used the Lookup parameter, double clicked the Lookup, added the correct properties in the Lookup Table, clicked OK, closed the Block Editor, and tried the Lookup parameters only to find it did not work.
Note: I am in online schooling and my instructors do not even understand my issue... 😞
Please find my attached issue.
