Dynamic Blocks keep losing functionality
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm experiencing an issue where my dynamic blocks stop functioning properly over time. I recall seeing a post about this a while back, but I haven't been able to locate it again.
These blocks have been in use for several years without problems, so I'm confident the issue isn't with the block definitions themselves.
I can remove the blocks, purge the drawing, and reinsert them—after which they work correctly for a while. However, at some point later, they stop functioning again.
Here are a couple examples of what I'm experiencing.
The block pictured below has grip points on all four quadrants, allowing the column bubble to be moved or inserted in the correct orientation. Eventually, the grips stop working as intended.
The block pictured below contains a rotation parameter for a span symbol, which eventually stops responding as intended.
