Dynamic blocks in content appears small
I have created some dynamic blocks that work just fine when inserted into a drawing.  The problem develops when loading the dynamic block into content.  The snapshot of the dynamic block appears real small instead of filling the block visible space.  I can insert a block into content and it appears just fine.  How do I get the dynamic block snap shot to appear full size in content.
I believe the block preview image "Snapshot" displays based on your final save of the block.
Open the block, ZOOM EXTENTS and resave
See if that does the trick.
No matter how it is saved, whether small to big or reversed, expanded or not, all the same size in the block or different sizes in the block, the snapshot display always appears small.
Jerry D. Ratzlaff
jdratzlaff@gmail.com
Greg.BurnsT9Y83
Open the block in block editor. Under visibility make all objects visible and zoom out. The largest visible object will determine the size of the preview window. Select any unneeded objects  to make visible then delete them. Also making sure all visibility states are in a small window will make the block preview full size.
