Dynamic blocks - attributes
coffeejeanpaul
Message 1 of 1
coffeejeanpaul
Good day.
I would like to add an attribute to a block so that when I path array the block the attribute value would change to the distance you set the array to.
I know you can do it with field insert ,position and then x co-ordinates.
I was hoping there is a similar method I can use for change of distance.
See attached images.
thank you in advance
Replies (0)
