Dynamic block to change attributes with the distance you path array it
coffeejeanpaul
coffeejeanpaul
Good day.
I was wondering is there a way you can put a count to a dynamic block.
Meaning if I path array it with a distance the value would automatic change by the distance.
As show in the image's
I found if you insert a field with x-position it changes as you path array it.
So the question is can the attribute do a similar function to that but with a distance ?
ojuris
something like this
ojuris
don't forget use REGEN
coffeejeanpaul
That sort of what I am talking about but your version is to constrained to the X co ordinate.
Attached is the path array I want to array to and the KP automatic change to the path array value say count 50 between each item.
Is that possible to create a smart block like that 😕
Thanks in advance
ojuris
First I would like to see a block that could make array along that path.
About attribute - I don't know solution in standard way. May be lisp?
coffeejeanpaul
The Block is just a block not a dynamic block . So with basic modify tools you can use path array to array to that path.
I was wondering if you could add a field to the attribute similar as a position field.
But instead of telling the position it reads the distance of the in between array.
for example I have an attribute in a block reading 0.000 I copy or offset it by 50 from the original block(using normal modify tools) Can the attribute have a field that makes it read the offset/copy distance.
If it can then I in my mind I think path array should do a similar action.
Seems it is not possible.
Thank you for the help tho
