Dynamic blocks - attributes
ikocev
ikocev
Dear All,
let me describe my problem: I have a dynamic block with 5 visibility states and every state has attributes.
Some of the attributes are set to hidden for some of the states but when I test the block the attributes are
still visible. Objects associated with the attributes obey the visibility states and those which are set to hidden
are working fine but for some reason attributes don't.
Thank you for your thoughts.
h_s_walker
Posting a drawing with the block in usually helps us determine the problem.
If you insert the block in a new drawing, do the hidden attributes still show?
Howard Walker
Left Handed and Proud
ikocev
@h_s_walker  I have attached a sample drawing.
When I insert the block in a new drawing, hidden attributes still show.
Thank you!
h_s_walker
You need to change the tag references on all your attributes. They all need to be unique.
e.g. TAG1 TAG2 TAG3 ….
Howard Walker
ikocev
It doesn't make a difference. I even created new attributes with different tag references and recreated the visibility states but still the same.
h_s_walker
Sorry, forgot to mention you need to LOCK the position of the attributes and do an ATTSYNC afterwards.
Howard Walker
ikocev
Many thanks mate, I greatly appreciate your help.
