I am having an issue where the attributes of the block are not showing up in the properties in model space. It is showing up as selectable lines in the attribute editor, but it is completely blank. I have tried ATTSYNC, BATTMAN->SYNC, copying the block to another drawing file, and closing and opening the drawing. None of it seems to work. Could someone check this block out and figure out what the problem is? Thank you!
