Dynamic Block adjustment based on Drawing Properties
larsXBAMW
larsXBAMW
Is it possible to make a dynamic block, dependend on drawingproperties?
A simple example:
A rectangle, with dimension1 and dimension2, both assigned the stretch action.
in drawing properties i have d1 and d2, which i can change.
Can I somehow make it work?
I know this is very simple, but if I cant make it like this, I wont go further 🙂
vinodkl
Hello @larsXBAMW
Something like this? Please see attachment.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Libbya
There may be ways with custom code, but with stock AutoCAD, no, drawing properties cannot drive changes to a block's dynamic properties.
larsXBAMW
No, this is just a normal dynamic block
