Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Dynamic Blocks Forum
Dynamic block wont align with another dynamic block using alignment parameter ?
10 REPLIES 10
Message 1 of 11
james6S5PP
534 Views, 10 Replies
Hi all, this is driving me nuts.
I have created a dynamic block with various visibility states and stretch parameters. I have added alignment parameters to this which aligns to lines and blocks successfully, but not to a copy of itself, nor other dynamic blocks with visibility states within them. Is there a way to make it so this block can align with a copy of itself?!
10 REPLIES 10
Message 2 of 11
h_s_walker
in reply to: james6S5PP
Your hatch is the problem. The alignment parameter doesn't like it. If you create another visibility state without the hatch the alignment parameter will work. Then you just need to change it back to the hatched state
Howard Walker
Left Handed and Proud
Message 3 of 11
james6S5PP
in reply to: h_s_walker
Even though the hatch has a polyline around it currently?
Message 4 of 11
h_s_walker
Yeah I even tried creating a new polyline which would be at the "front" and even using that if the hatch was present the alignment parameter wouldn't work
Howard Walker
Message 5 of 11
james6S5PP
thats annoying.
Message 6 of 11
james6S5PP
these seems to only be an issue with solid hatches.
anyone see a way around this so i can keep the solid hatch?
Message 7 of 11
h_s_walker
Does it need to be a hatch? Are you just using it to mask what's behind?
If you are use a wipeout
Howard Walker
Message 8 of 11
james6S5PP
yes it needs to be solid hatch unfortunatley.
Message 9 of 11
h_s_walker
Why not do as I suggested. Create another set of visibility states which don't have the hatch and use a double lookup, to turn the hatch on and off
Howard Walker
Message 10 of 11
james6S5PP
its not ideal. This is a block from a drawing template for a partition that has 8 or 9 visibility states already, which all vary in width. if there is to be another 9 visibiliy states for each current state, then this wil lbe very confusing for my design team!
Using the AL command would probably be easier for them if this is the case.
Message 11 of 11
h_s_walker
@james6S5PP
If they only vary in width as I saw with your visibility states, why don't you use a lookup parameter to change the non changeable width, and then you can do it.
You could do it with max 6 visibility states
Normal
Insulated
Moisture
Normal without hatch
Insulated without hatch
Moisture without hatch
Howard Walker
AutoCAD Inside the Factory
