Dynamic block with XY array, XY stretch and with set space between rectangles
I need to make a dynamic block (rectangle) with these characteristics:
- The rectangle needs to be stretched in both X and Y axes.
- I need the rectangle to be arrayed in both X and Y axes.
- I also need to keep the space in between rectangles (horizontal and vertical) fixed to 3 units.
I have no problem creating the block and adding the XY stretch properties, but the issue comes when creating the XY array, as I need to specify a dim but as mentioned, I need this to always be 3 units in between rectangles, I need to be able to stretch my rectangle to any size, use the XY array, and always have a 3 units space in between rectangles. I have attached a sample. Once you stretch the main rectangle, the rest start to overlap, which is not what I want.
Your help is greatly appreciated.
