Help with an array function within a dynamic block
DLynchCGUTR
DLynchCGUTR
Hello all, I'm seeking some assistance with the attached block
what I'm trying to achieve is to make the overall size of the entire item stretchable. (a dim )
when I stretch the item, I need the u-shaped items (B) (green) to array to fill in the space so there is no open space.
I normally have more time to poke at this issue and learn on my own but I don't at the moment.
thanks, in advanced for any support and help
Dan
MMcCall402
I remade the Arraypath and used the red line just below the green U-shaped items as the "path".  This red line stretches as the canopy stretches, and so, the array follows it and makes more of the green U-shaped items.
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
DLynchCGUTR
THANKS SO MUCH, I ALWAYS FORGET THE PATH LINE
DLynchCGUTR
I KEEP ENDING UP WITH A GAP BETWEEN THE ARRAY AND THE LAST FULL U-SHAPED ITEM, ANY IDEAS ON THIS? MY SPACING SEEMS CORRECT IN THE ARRAY, SHOULD I JUST MAKE THE LAST ONE A PART OF THE ARRAY?
MMcCall402
Try setting the array spacing to exactly 6.  It was 6.0025 in the initial block and I just copied it as it was. Then adjust the end piece to match.
Mark Mccall
CAD Mangler
Linkedin
