Dynamic block with Stretch and Rotate attribute
rbh1
rbh1
Does anyone know what is wrong with this block?
I'm trying to get it to stretch and rotate but keep the attribute horizontal.  the attribute rotates and stays horizontal but does not stay in the right place.
When stretching at 90 or 270 the lines go horizontal instead of verticle.
Libbya
The issue is caused by rotating the stretch actions.  When you rotate a stretch action, you dynamically alter its angle offset property.  In this case, the associated parameter is also rotated, so the combination causes the angle change to double.  I also fixed the attribute point/move issue.  See screencast.
lena.talkhina
Hello @rbh1 !
Great to see you on Autodesk Community forums.
Did @Libbya 's post helped you to find a solution? If so, don't forget to accept it as a solution.
If not, well, don't hesitate to update information here in you thread, so others could see that you still looking for answers.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
