How to flip attributes in dynamic block?
After fliping - attribute stay in same place.
Please check attached dwg.
Thank you 🙂
Tadas
Thank you 🙂
Tadas
Solved by ojuris. Go to Solution.
hi!
Set for attributes Lock position to Yes
hi!
Hello, I'm popping up this old thread because I can't manage to get my attribute to flip like your, even with LOCK POSITION checked on... My attribute just never flips
Thanks in advance for your help
When you do something with attributes in block, use ATTSYNC command
see attached
see attached
