- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi there
I have just begun trialing dynamic blocks and have created a window in plan view with 3 visibility states. Im ok with stretching the first single pane window, but having trouble when I split window into 2 or 3 sections. I am using distance multiplier with stretch action but part cant get one line to move correctly.
Would appreciate some help plz.
I will attach my block if someone could look at it.
If you go to Double pane in visibility states, you will see that one line is not moving correctly in stretch action1, the other middle lines move at 0.5 distance multiplied. Tried seperate actions on same parameter and new parameter chained to first stretch action. Want all to middle section to move with the one grip. Then I want to add grips to slide middle sections back or forward seperately. I am using AutoCAD LT 2017 so do not have constraints either.
Mac
