Dynamic Block Visibility States work independently but not together
MelissaL6HXA
Message 1 of 10
MelissaL6HXA
I am new to Dynamic blocks. I have learned a little here and there but not a lot. I was tasked to "learn" how to adjust and create dynamic blocks for our library.
I created a 3 drawer base with 3 visibility states. Each state has a few actions associated with it (all the same).
  1 - the height will change 30", 34" or 36"
  2 - the bottom two drawers will remain equal size with each height change (top drawer stays the same always)
  3 - the toekick adjust 4", 5" or 6"
The 3 visibility States are Pulls, Locks and No Pulls.
Here is my issue - When I test the block each visibility works as it is supposed to UNTIL I switch to another visibility - the visibility I switch to does not adjust properly and takes on part of the original test block attributes. Example - if I test the Pulls visibility every state works as designed. When I switch visibility to Locks, the locks and pulls are not where they should be (the actions are stuck in the wrong place). BUT when I start over and start with the Lock state - the lock actions all work but the pulls state actions get messed up. What did I do wrong and how do I fix this?
Any help would be so much appreciated.
Replies (9)
Message 2 of 10
h_s_walker
You're using too many parameters. One parameter can be in multiple visibility states if it needs to move the same stuff around. See the image below for putting parameters in multiple visibility states and see the attached drawing and compare the block on the right (the one I edited) with your block
Howard Walker
Left Handed and Proud
Message 3 of 10
MelissaL6HXA
I see what you did and did exactly what you did but am still having that same problem. I have the exact same parameters chosen as your edited block - what did I do wrong?
Message 4 of 10
h_s_walker
Post your updated block
Howard Walker
Message 5 of 10
MelissaL6HXA
here you go - sorry about that
Message 6 of 10
MelissaL6HXA
I think I figured it out - I needed to re-do the parameter in the lock visibility state; reconnecting the objects I want with that action to move the locks. I will need to do the same with the base action also - Correct?
Message 7 of 10
h_s_walker
One of your problems is you're doubling up on your handle blocks. See the image below
What I would suggest you do is delete the other states but keep locks. Make sure you're not duplicating any linework or blocks.
Make sure locks works as you want. Then all you need to do is recreate the other visibility states and just hide the linework / blocks you don't need
Howard Walker
Message 8 of 10
MelissaL6HXA
That describes it very easily. It sounds so simple.
Basically - so I know I understand - I create 1 block - make that work the way I want it to. Then use my visibility states to bring forward or push behind items in the block I already created along with all the actions in that visibility state. Anything in the visibilities should be from the ORIGINAL block only. So if I have a more complicated block I should do the most complicated first and work my way backward to the simple in the dynamic blocks. Does that sound correct?
Message 9 of 10
h_s_walker
Yeah that sounds about right, but if you make sure the red ringed item (see the image below) is selected then all you need to do is hide the items (blue ringed item) you don't need.
Howard Walker
Message 10 of 10
MelissaL6HXA
Thank you for all your help!
