- Mute
- Permalink
- Report
I've created a dynamic block to show 4 types of electrical outlet symbols in one block; it also has a rotation action. The two actions (visibility and rotation) both seem to work fine if I use the rotation first. If I change the visibility state and THEN rotate, the rotation grip remains at the original location rather than following the rotation of the block, and some of the visible items will remain at the original location which makes the block useless. I've remade this a couple of times and can't figure out the issue. I am using AutoCAD 2020 with legacy menus (no ribbons or palettes) I am NOT versed at all in lisp and would rather have a step by step solution. Thanks.
