Dynamic block - text / rotation
leticia.campanelli
leticia.campanelli
Hi there,
I am creating a block for the grid line. The idea would be that it would rotate as needed but the text - grid line number would always be horizontal.
I know how to create this scenario by adding a rotation option for each text, which is time-consuming to change every time.
What I am wondering is the following:
Is it possible to add a property to that specific text to always be horizontal? Even when the block is rotating?
Please say yes 😁
I hope I was clear.
h_s_walker
Both ringed items need to be ticked
Howard Walker
Left Handed and Proud
leticia.campanelli
Thanks for the suggestion.
It seemed like a straightforward solution.
For some reason, it is not working
Please see the block attached -  if you could please point out why it is not working I would really appreciate it.
h_s_walker
I couldn't get it working today. I have got it working before, but I've got a better solution. Remove the two "letter" attributes from all the actions. Add a point move to both of them. Add the "main letter" point move to the rotate action. Add the "field" point move to the stretch and rotate actions. Set both attributes lock position to yes and change the Chain Actions property of both point moves to yes. See the attached drawing.
Howard Walker
jtohillVY4VS
Here is one I use.
leticia.campanelli
That is a fantastic solution!
thank you so much!
