Dynamic Block Stretch with Constraint for Distances Between Arcs
olivier_ponton
olivier_ponton
Im trying to make a dynamic version of an Elbow 90 for HVAC duct.
I added a visibility parameter that change the duct appearance depending it has thermal / acoustic insulation or not. Thats working fine. My problem is that I want to be able to change the elbow dimension so Im using the distance parameter with the scale action applied but I want my insulation lines to always stay the same distance from the duct itself.
I dont know how to use constraint to lock the insulation thickness during the scale operation.
j.palmeL29YX
One of several ways:
If you have further questions, feel free to ask.
Jürgen Palme
olivier_ponton
Thank you,
I appreciate the detailled video and it answers my problem. As I read back my post, I've noticed I mentionned having problem stretching while keeping the same distance. Actually, i would need to scale the elbow entirely to keep the ratio between duct size/interior radius and exterior radius (Duct diameter = D , Interior Radius = D/2 , Exterior Radius = 1.5 D ).
j.palmeL29YX
Attached a new (hopefully improved 😉 ) version. I hope you can explore (without video) how I did that.
Jürgen Palme
olivier_ponton
Yeah. That works very well. Thank you for the precious help.
