Hi Community.
I have created a block to reference a data cabinet.
I have added all the paramerters that I want the block to have.
The issue is when I rotate the block after i have stretched it to size, the text in the middle will sit outside of the block.
I want the text to stay centre of the block, this works fine up until I rotate the block after the stretch has been used.
I have attached a DWG for reference.
The left side is before stretch/rotate is used and text works fine.
Middle is stretch after rotation used and text is still working correctly.
Right side is rotation used after stretch and issue appears.
Many thanks
