DYNAMIC BLOCK STRETCH PARAMETERS
I am working on a dynamic block for a multi-hole restroom. My goal is to be able to stretch vertically and horizontally while keeping the sinks, door, and the toilets in the same place as it stretches. However I also want the urinals to array in the men's restroom and I want the stalls to array in the women's as I stretch the restroom vertically.
I should make a correction i want the sinks to move with the vertical stretch parameters and stay the exact same distance from the nearest corner as it stretches.
Libbya
I made the following screencast prior to your last post so I did not stretch the sinks with the wall, but that can also easily be done.  Just add the sinks to the stretch selection set and make sure the window surrounds them.  shows how to do a simpler method of the double lookup control and shows the technique necessary for making whatever arrays you like.  I added one for the urinals.  Following the same technique, you can add another appropriate chained linear parameters and array actions for whatever arrayed objects and spacing you like in the various views.  Let me know if you get stuck or have questions.
